[Qgis-user] Cutting lines with a polygon boundary
Andre Joost andre+joost at nurfuerspam.de
Sun Jan 25 10:23:37 PST 2015
Am 25.01.2015 um 13:51 schrieb Zoltan Szecsei:
> So, does anyone know of a way to efficiently cut features in multiple
> layers using a polygon, and then to be able to select the pieces
> (multiple layers) that are either inside or outside the polygon, and
> then delete them?
Disregarding the "multiple":
"Vector -> Geoprocessing -> Clip" deletes the items outside the polygon
"Vector -> Geoprocessing -> Difference" deletes the items inside the polygon
You would have to do it for every layer you want to be cut, the dialogue
box will stay open after cutting. If the polygon layer contains just one
polygon, no selecting is necessary.
BTW: make sure all layers share the same CRS (i.e. turn
on-the-fly-reprojection off)
HTH,
André Joost
