[Qgis-user] R: RE: RE: (no subject)
labiancamarilena at libero.it
Wed Jan 28 10:06:47 PST 2015
Hi Phil,thanks a lot!Marilena
----Messaggio originale----
Da: phil at wyatt-family.com
Data: 27/01/2015 23.41
A: <labiancamarilena at libero.it>
Ogg: RE: RE: [Qgis-user] (no subject)
-->Hi Marilena, There are quite a few tutorials about geocoding. A quick Google search with the terms .. QGIS geocoding .. returned plenty of leads. As always there are multiple ways this can be done so don't be afraid to try the geocoding from a few different services especially if the address locations are in rural areas. Some systems work best in cities, others in lesser known areas. https://www.google.com.au/search?q=qgis+geocoding&ie=utf-8&oe=utf-8&gws_rd=cr&ei=AxLIVMXfPMmD8gXStICoCQ#q=qgis+geocoding Given QGIS is open source there are lots of samples and websites that can help you through almost any process. Have fun! Cheers - Phil From: labiancamarilena at libero.it [mailto:labiancamarilena at libero.it]
Sent: Wednesday, 28 January 2015 6:37 AM
To: phil at wyatt-family.com; qgis-user at lists.osgeo.org
Subject: R: RE: [Qgis-user] (no subject) Dear Phil, great!Thanks a lot!It's a fantastic plugin, but are there videos or other sources for the best use of this plugin? Thanks a lotMarilena ----Messaggio originale----
Data: 26/01/2015 23.51
A: <labiancamarilena at libero.it>, <qgis-user at lists.osgeo.org>
Ogg: RE: [Qgis-user] (no subject)You will need to somehow assign geographic references (Lat/Long) to each address. This might be achieved by geocoding from the addresses. Under plugins, check if the experimental MMQGIS plugin is loaded. This has a menu item for geocoding the addresses from Google and Open Street Mapping. Cheers - Phil From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of labiancamarilena at libero.it
Sent: Tuesday, 27 January 2015 2:20 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] (no subject) Dear all,
I should add a spreadsheet with data containing the addresses of commercial activities to be loaded in QGIS.
The spreadsheet (Excel) contains the name, code, complete address, city.
How can I assign these values properly if I want to use open layer plugin with a road map of Google?Thanks
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2015.0.5646 / Virus Database: 4273/9007 - Release Date: 01/27/15
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150128/3e5a482f/attachment.html>
