[Qgis-user] QGIS 2.6.1 Complex polygon not displayed properly
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Jan 29 08:04:13 PST 2015
How are you importing or exporting the polygons? Are the files originally shapefile? Are you using QGIS for the import/export or an other software?
When you click on a lake, is it associated with a line in the database? If not, it could be more of an rendering issue rather then a import/export issue.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-01-29 10:46, "simonc8 [via OSGeo.org]" <ml-node+s1560n5184481h72 at n6.nabble.com> a écrit :
I append two images of the same shape file which contains a single polygon with several "lakes". In SAGA it displays correctly with all the lakes as transparent but in QGIS the larger lakes contain the colour fill. Is there something I'm not doing correctly in QGIS, or is there an option for changing the way it imports a polygon?
Grateful for assistance.
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGIS-2-6-1-Complex-polygon-not-displayed-properly-tp5184481.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-2-6-1-Complex-polygon-not-displayed-properly-tp5184481p5184483.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150129/d17751e0/attachment.html>
