[Qgis-user] Unable to add values to text string attributes
    Brent Wood
    pcreso at pcreso.com
    Fri Jan 30 17:18:45 PST 2015
 Hi Michael,
I'm (definately!) not a dev, but maybe can help....
I think the update all & update selected buttons pertain to the field calculator just to the left of the buttons, otherwise the editor is one row at a time.
If you enter a string value in the column, then press enter, it will be saved.
To use the field calculator, select the field you want to update (left hand pick list), then enter the formula defining the value...eg:  for a simple string, for a 64 char text field called test, you finish up with the formula:
test='HYT'
(note that strings need to be quoted, numerics don't)
then apply this to all or selected columns via the two buttons...
HTH,
   Brent Wood
     From: Michael Grosberg <grosberg.michael at gmail.com>
 To: qgis-user at lists.osgeo.org
 Sent: Saturday, January 31, 2015 3:52 AM
 Subject: [Qgis-user] Unable to add values to text string attributes
so, umm, hello, first time here.
First of all, if any of the developers sees this - it's a wonderfull tool
and a joy to use. Now, my question: I have a vector layer (ESRI shapefile)
and I'm trying to fill some values. numerical values - no problem. I select
some points (this is a point file), type the value I want, press "update all"
and the column is filled with the value. But I tried the same with a text
string (I created a new column and set it to type "string", made it
64 characters long to be safe), and it doesn't seem to work. after creation,
the entire column has the value "null", but try as I might to enter a value
and press "update all", this does nothing. If I do the same using a digit
(and remember, this is a string attribute!), that DOES work for some reason.
Any ideas what's going on? I've just tested it at home and the same problem
exists, so it's not just my work PC.
Oh, and another question, although I'm pretty sure the answer is no:
I need to outline building outlines, which I currently do using other apps.
But I'd love to switch to working with Qgis fulltime.
Does QGIS have tools / plugins to help with drawing orthogonal shapes?
I'm thinking about something that would let me draw one line freehand and
then the rest of the lines would be constrained to be parallel or orthogonal
to the first line. Alternatively something that would take a freehand-drawn
polygon and straighten it.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150131/0a14a429/attachment.html>
