[Qgis-user] get length of "custom" geometry in expression
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Mon Jul  6 09:03:21 PDT 2015
Kristian, thanks for your explanation. I will check the function editor.
Richard, your solution would not solve my problem as I still use
$length. But as a workaround I saved my layer in the CRS I needed and
used the $length function in the label expression.
Regards,
Raymond
On 06-07-15 09:04, Kristian Evers wrote:
> I think your problem is that length() returns the length of a text-string, and not the length of a geometry. As the geometry isn't a string, the output is 0.
> As far as I can see it is not possible to do what you want with the default functions in the field calculator. With a bit of python in the function editor it should be possible.
> Kristian
> -----Oprindelig meddelelse-----
> Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Raymond Nijssen
> Sendt: søndag 05. juli 2015 19:49
> Til: qgis-user at lists.osgeo.org
> Emne: [Qgis-user] get length of "custom" geometry in expression
> Im' trying to do this in my label expression:
> length($geometry)
> but it always returns 0. Is there a way I can do that? I tried
> getlength() and getLength() as well, without luck.
> I know there is the $length which works on the geometry right away, but
> i am performing a transformation first:
> length( transform($geometry, 'EPSG:3857', 'EPSG:3006') )
> Hoping anyone can help!
> Raymond
> Qgis-user mailing list
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
