[Qgis-user] aggregate map of maximum value
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jul 7 07:49:39 PDT 2015
I am not sure you can use max value in QGIS raster calculator. (Please correct me if I am wrong).
I think you can do it with gdal calc.py. and most likely in Grass or Saga using the processing plugin.
http://gis.stackexchange.com/questions/107257/combine-overlapping-rasters-in-gdal-calc-py-taking-the-maximum-value-from-each
If you want more flexibility but don't mind the lost of speed, you could convert the raster in a vector format and use the field calculator to do it. This work's OK up to a few million points or pixels. After that, it's very slow. You can speed things up by using R for the statistics.
I think there is a raster to point module in the QGIS processing plugin or just look at this:
http://fr.slideshare.net/shencoop/qgis-raster-to-point
Then you could do the reverse operation on the results.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 7, 2015 8:06 AM, "Giacomo Fontanelli-2 [via OSGeo.org] " <ml-node+s1560n5214622h43 at n6.nabble.com> wrote:
dear community I have a stack (bsq) of 5 images. I would like to make an aggregate map of the maximum of each pixel of the bands. I Googled and I found contrasting opinions on how to do it. Can you help me? Thank you
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/aggregate-map-of-maximum-value-tp5214622.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/aggregate-map-of-maximum-value-tp5214622p5214684.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150707/d05e1ee3/attachment.html>
