[Qgis-user] Deleted decimals in field calculator
    Francesc Cañas
    kikocanas at gmail.com
    Sun Jul 12 09:23:51 PDT 2015
Hi Delaz,
You were right, the width refers to the global width, including decimals, I
thought they were two different things. And yes, that causes the problem,
thanks a lot!
2015-07-10 12:50 GMT-05:00 DelazJ <delazj at gmail.com>:
> Hi,
> Francesc, I may be wrong since I couldn't find the reference in QGIS docs
> nor elsewhere but I'm not sure you can have a field width at 3 and decimals
> at 3. The width is supposed to be the total of all digits, meaning the
> digits before the comma and those after the comma. In your case you should
> have width 6 and precision 3.
> Try with this and let us know.
> DelazJ
> 2015-07-10 19:39 GMT+02:00 José Antonio Barreña Cayuela <
> jabarcay at gmail.com>:
>>  Perhaps the problem is the operating system or program language
>> (spanish, english....).
>> El 10/07/15 a las 18:52, Francesc Cañas escribió:
>> No, it's not integer or float with no decimals. They don't dissapear when
>> I save, they turn to 0 but with the same accuracy intended. If I create a
>> field with 3 width and 3 decimals, while operating displays 123.321 but as
>> soon as I save it turns to 123.000, the same for 4 decimals and so on.
>> 123.0000. It's driving me crazy.
>> 2015-07-08 10:53 GMT-05:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
>>> Hi,
>>> Maybe you creating an integer field and not a float field (or a float
>>> field with no decimals) by mistake?
>>> Nicolas Cadieux M.Sc.
>>> Les Entreprises Archéotec inc.
>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>> Téléphone: 514.381.5112  Fax: 514.381.4995
>>> www.archeotec.ca
>>>  On Jul 8, 2015 11:19 AM, "Francesc Cañas [via OSGeo.org] " <[hidden
>>> email] <http:///user/SendEmail.jtp?type=node&node=5214893&i=0>> wrote:
>>>    Hi,
>>> Several times when I've created a float field with the calculator, while
>>> it isn't saved, it displays the decimals, but as soon as I save the
>>> changes, all of them change to 0. Why this happen? It seems random to me,
>>> in some shp work well but in others doesn't.
>>>  Thanks a lot.
>>>  *Francesc Cañas <http://francescsig.info/>*
>>> Ambientoleg SIG <http://francescSIG.info>
>>>  <http://aixonoesunblog.blogspot.com>
>>>  _______________________________________________
>>> Qgis-user mailing list
>>> <a
>>> href="/user/SendEmail.jtp?type=node&node=5214880&i=0">[hidden
>>> email]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> http://kikocanas.tk
>>>  If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/Deleted-decimals-in-field-calculator-tp5214880.html
>>>  To start a new topic under Quantum GIS - User, email
>>> <ml-node%2Bs1560n4125267h38 at n6.nabble.com>
>>> ml-node+s1560n4125267h38 at n6.nabble.com
>>> To unsubscribe from Quantum GIS - User, <a href="
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node&%2361;4125267&code&%2361;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&%2361;&%2361>
>>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
>>> here.
>>> <a href="
>>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
>>> style="font:9px serif">NAML
>>> View this message in context: Re: Deleted decimals in field calculator
>>> <http://osgeo-org.1560.x6.nabble.com/Deleted-decimals-in-field-calculator-tp5214880p5214893.html>
>>> Sent from the Quantum GIS - User mailing list archive
>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>>> Nabble.com.
>>> Qgis-user at lists.osgeo.org
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>> *Biólogo (botánico). Servicios Medioambientales*
>> *+34 677 811 883* · <jabarcay at gmail.com>jabarcay at gmail.com
>>    [image: skype]   [image: linkedIn]
>> <http://es.linkedin.com/pub/jos%C3%A9-antonio-barre%C3%B1a-cayuela/26/936/15a/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150712/cae2ad01/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150712/cae2ad01/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150712/cae2ad01/attachment-0001.png>
