[Qgis-user] HELP Please: SAGA, GRASS 6 & 7, R, do not work in vers. 2.4 -. 2.8
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Jul 14 06:33:08 PDT 2015
I find the easiest way to install is to:-
1. Backup python Plugins(C:\OSGeo4W64\apps\qgis\python\plugins for
Python Plugins)
2. Delete the OSGEO4W folder
3. If you have other versions of the software installed via standalone
installers, uninstall all the Programs (QGIS,GRASS, SAGA etc)
4. Run a search for QGIS and delete any other folders (besides your
Backup...be careful)
5. If you don't have ccleaner or similar install it, click on Registry
(Left icon second from top), Scan for issues & then Fix selected
issues, repeat untill there are no issues.
6. Download most recent version of OSGEO4W installer (not standalone
QGIS installer see http://trac.osgeo.org/osgeo4w/ )
7. Do a standard Desktop instillation, It will install QGIS GRASS SAGA
and uDig, R should also be installed (Im open to correction)
8. When you have finished over wright the plugins folder with the backup.
9. Now you may have some issues initially, but redirecting is easy
enough, just direct everything to the corresponding OSGEO4W folder.
This is what I remember having to do with my last instillation, I cant
currently verify the above, as I don't have sufficient rights on my Work
PC at present.
Regards,
Richard.
On 14/07/2015 12:18, Bernd Vogelgesang wrote:
> Hi,
> maybe your paths are mixed up from all those different updates and
> versions you installed.
> From my experience, updating versions of QGIS rarely runs smoothly, so
> I always make "tabula rasa".
> Under Windows, I uninstall everything connected with QGIS
> remove/rename the .qgis2 folder and delete all registry entries of
> QGIS with regedit.
> When reinstalling, I found the OSGEO4W-installer with advanced install
> mode had the best results (but harder to understand).
> If you want to go this way, be sure to write down all the plugins you
> would like to have, save own scripts or model etc. to a safe place.
> You might still have problems when your paths in the Windows
> enviroment variables are twisted as well.
> Just my 2cents. If other know better ways to solve those problems,
> please comment.
> Cheers
> Bernd
> Am 14.07.2015, 12:26 Uhr, schrieb Velizar Strumberger
> <velizar.strumberger at gmail.com>:
> Hello to all
> I am a great admirer of QGIS but I have a serious problem and I
> hope that there is someone that can help me. I started working
> with QGIS 2.2 (Valmiera) and it worked OK. I then (tried to)
> switched to QGIS 2.4 but then GRASS, SAGA and R stopped working.
> I have a laptop Windows 7 64 bit and a desktop Windows XP 32 bit.
> The phenomenons are the same.
> Installing it as a standalone or with OSGeo4W gave the same results.
> These are the problems:
> GDAL: OK it woks
> For *GRASS 6 and 7*: Missing dependency. This algorithm cannot be
> run :-(
> This is for *SAGA and TauDEM* : Ooooops. The following output
> layers could not be open
> Channel Network C: /and a log path /...........................
> The above file(s) cannot be opened, which probably indicates that
> they were not correctly produced by the executed algorithm.
> *For R*: Missing dependency. This algorithm cannot be run :-(
> * Orfeo Toolbox*:
> OTB folder not configured. Please configure before running OTB
> algorithms.
> (This also didn't work in QGIS 2.2 but I didn't bother with his).
> In the Processing->Options->Providers the paths for
> GRASS 6.4.3 was C:/OSGeo4W64/apps/grass/grass-6.4.3/etc/grass-run.bat
> and for MSYS
> C:/OSGeo4W64/apps/msys/msys.bat
> This is wrong because I installed a standalone version and there
> is no OSGeo4W64 folder.
> I corrected the paths for both and pressed OK. I opened the
> Providers once again and saw that the two path were converted to
> the "original" ones that I "changed"; there is no way I can change
> the paths set up during the installation
> There is also a path for GRASS 7, but this was not installed.
> I have the impression that parameters for the Providers is from
> the previous installation through OSGeo4W - the previous installation.
> I truly believe that I did not uninstall or delete a file (I also
> think that the first time I did not uninstall but just deleted
> QGIS) that determines such behavior because I also noticed the
> following:
> When I install QGIS (any version) and install some plugins (which
> I would never use - as a test) and open the toolbox with several
> providers and when I uninstall this version and install it once
> again I find that the same plugins are installed and the toolbox
> is opened exactly the same as I left it in the previous installation.
> I am not a computer wiz but just a humble geologist who wants to
> use software for my work.
> Help - or explanation how to correct this would be most welcome.
> Regards
> Dr. Strumberger
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150714/d4b5b57b/attachment.html>
