[Qgis-user] Adding a Oracle Spatial Layer without a SRID Value at the geometry column
johannes johannes.anger at brawag.de
Wed Jul 15 03:02:41 PDT 2015
we have some problems to add a oracle spatial layer in QGIS.
Following situation at our oracle spatial database (Oracle 11g):
The Database-Table has an index on the geometry column, but no declared
primary key. Caused by a false EPSG 25833 system, the geometry column has no
SRID value.
Following reaction of qgis 2.11 Nightly (QGIS e679b0b):
The Database-Table is identified as a spatial layer with the SRID -1, the
correct geometry type and can be added as a layer. After adding I don't see
any objects in qgis. I've got following notice in the protocols:
*Protocol Qt*
/2015-07-14T16:11:44	1
..\..\..\..\..\..\..\src\providers\oracle\ocispatial\qsql_ocispatial.cpp:
3011: (QOCISpatialResult::gotoNext) goto next error:  [ORA-00932:
Inkonsistente Datentypen: BLOB erwartet, ARRAY erhalten]/
*Protocol Oracle*
/2015-07-14T16:11:19	1	Oracle SRID -1 nicht gefunden./
If I delete the index from the geometry column at the oracle database, add a
new srid value (faked EPSG 325833), add a new index on the column the
problem is solved. Is there any way to solve the problems without changes at
the main oracle spatial database. Due to dependencies to a second GIS
product it's not possible to update the entire database atm.
What can i do?
Best regards,
Joe
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-a-Oracle-Spatial-Layer-without-a-SRID-Value-at-the-geometry-column-tp5215702.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
