[Qgis-user] Saving a polygon in QGis before to edit it
Matthias Kuhn
matthias at opengis.ch
Mon Jul 20 04:05:54 PDT 2015
I remember geogig (formerly geogit) offers promising concepts for
filebased spatial data management with historization and branching.
Unfortunately I don't know the current status of the project and the
progress of integration in QGIS.
Matthias
On 07/20/2015 11:25 AM, Neumann, Andreas wrote:
> Hi Didier,
> I don't think that anyone is working on a client-side historisation
> option in QGIS. And there wasn't much demand for that in the past,
> since most serious GIS data resides in databases.
> Andreas
> On 2015-07-20 09:45, didier peeters wrote:
>> Hello Andreas,
>> yes it's for some 'historisation', more precisely to make a
>> filiation, and yes I certainly will use triggers in PostGIS. But I
>> wanted to avoid confusion between different kind of edition
>> operations that I'm not currently foreseeing; I'm not sure it will
>> always be easy to distinct this specific action from others. And I
>> thought that it might also be interesting outside of the database
>> world, to have that "edit and preserve" operation.
>> Didier
>> Le 20 juil. 2015 à 09:10, Neumann, Andreas <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> a écrit :
>> Hi Didier,
>> Is this for historisation purposes? If yes, I would look into
>> database solutions to do historization.
>> The SQL-MM standard has this as a built-in tool set for
>> databases, however, PostgreSQL does not implement this part of
>> the SQL specification (I believe the latest versions of SQL
>> server and Oracle 12 does). However, you can simulate the same in
>> Postgis, using triggers and rules.
>> Andreas
>> On 2015-07-20 08:00, didier peeters wrote:
>> Hello,
>> I would like to find the best solution to the following case:
>> in QGis, when editing a polygon (splitting it in 2 parts) I
>> need to save the original shape, in order to keep the
>> different steps of its evolution; this operation is likely to
>> be repeated several times. The solution I found is to
>> * start by copying the polygon,
>> * then edit it (split)
>> * then pasting back the original one,
>> * then adjust and update the attributes of the 2 new
>> polygons.
>> Is there a less tricky way to achieve this ?
>> If not it would be nice to have an option in the save dialog
>> (with a default behaviour set in the Settings), and I would
>> file a feature request.
>> Didier
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150720/c3efee9f/attachment.html>
