[Qgis-user] Small maths problem!
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Jul 23 09:07:11 PDT 2015
Andy,
That might just work, I will give it a go...Will let you know how I get
on, at the moment, I have the style saved to the database, it will be
interesting to see how that all works!!
Regards,
Richard.
On 23/07/2015 12:36, Andrew Harfoot wrote:
> Just a thought Richard, but if you don't need to edit the data, could
> you not use a join to add a (precalculated) rotation field on the fly,
> either on the DB side, or in QGIS?
> Cheers,
> Andy
> On 23/07/2015 09:10, Richard McDonnell wrote:
>> Hi,
>> I am in need of some guidance, I am trying to create an "active
>> hatch/Fill" as part of a style im working on. What I want is for a
>> hatch to rotate depending on the orientation of a Polygon.
>> For example, here is the same entity rotated, with the hatch rotating.
>> The issue is I am working on a database, onto which I cant add any
>> data (additional columns) to the tables, I would like to do this from
>> within the styling.
>> You can use an expression to denote the angle, so I was hoping to do
>> it that way.
>> I was looking to utilize the geometry of a bounding box, and
>> calculate the angle of the diagonal, using something like
>> 180*atan((ymax - ymin)/(xmax - xmin))/$pi + 90
>> But I am not having any luck....If there is no way at present to do
>> this, Might I put it forward as a possible new feature?
>> Regards,
>> Richard.
>> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
>> OPW - Looking to the future - Caring for the past
>> <http://www.opw.ie/>
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andy Harfoot
> GeoData Institute
> University of Southampton
> Southampton
> SO17 1BJ
> Tel: +44 (0)23 8059 2719
> Fax: +44 (0)23 8059 2849
> www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/0c587892/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/0c587892/attachment.png>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/0c587892/attachment.vcf>
