[Qgis-user] Layer question
Shane
shaned173 at gmail.com
Fri Jul 31 21:28:07 PDT 2015
On 07/31/2015 06:50 PM, Tom Lennon wrote:
> Hi Shane
> Is it that you want the parking lot and the road outline to disappear
> if the road touches the parking lot?
Yes, it is. Thanks for the idea - I hadn't though of that
(obviously). Easier than drawing polygons - although another post
suggested a method to convert lines to polygons which I might try just
to see how it goes.
Shane
> You can do that if you use a different way to outline the roads and
> parking lots.
> You need to duplicate both the road layer and the parking lot layer.
> Then use one road layer to make fat black roads and the other to make
> thin gray road fill.
> Then use one parking poly to make fat black parking lots (fat
> outlines) and the other to do the gray fill with no pen outline.
> The trick is in the arrangement of the layers, it should be:
> Parking lot gray fill on top
> Road Gray fill
> Parking lot fat black
> Road Fat black on the bottom
> Hope that is what you wanted.
> Tom
> On Fri, Jul 31, 2015 at 4:09 PM, Shane <shaned173 at gmail.com
> <mailto:shaned173 at gmail.com>> wrote:
> Hi Bernd and all other responders,
> On 07/30/2015 05:50 PM, Bernd Vogelgesang wrote:
>> Hi Shane,
>> I think without a screenshot, we have no chance to really get an
>> idea what it's all about.
> I'm going to try inlining some small pics ... I don't want to
> create another account on another website just to post two pics.
> With any luck these pics won't be scrubbed by the list.
> Below is how the current map is rendered. The road layer is
> below the parking lot layer and the parking lot layer has no
> outlines. The road layer has thin, black outlines. Note that the
> gray areas have no black lines across them. This is the desired
> outcome.
> But I want to the parking lots to also have black outlines.
> When I set this up, I get the following pic which shows the black
> outlines rendered on top of the roads.
> Swapping the order of the layers only exchanges road outlines
> for parking lot outlines (not shown). The blending options don't
> change the outcome and sometimes adversely affect the colors. I
> am virtually certain that I need to convert the roads to polygons
> and merge them with the parking lots.
> Shane
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> tolennon at gmail.com <mailto:tolennon at gmail.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150801/d18674dc/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150801/d18674dc/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150801/d18674dc/attachment-0001.png>
