[Qgis-user] Couldn't load SIP module.
Saulteau Don
sault.don at gmail.com
Mon Jun 1 15:42:48 PDT 2015
Hey,
You can try a couple things. This error rears its ugly head all the time.
Things to try:
1.) Recompile the following packages from the ABS in the following order:
sip, pyqt4, qscintilla
a) Then recompile QGIS.
2.) Check the "sources" portion of the PKGBUILD and see if it's because of
the console.py patch being masked out. You can reference the qgis PKGBUILD
to see how that patch is applied in the "prepare" section. This console.py
patch hasn't been merged into upstream yet, though a pull request was
issued some time ago now. IMO it should be merged ASAP because it's a
breaker bug.
Donovan
On Mon, Jun 1, 2015 at 2:26 PM, Tomas Lanczos <tlanczos at gmail.com> wrote:
> Hello everybody,
> I installed the QGIS 2.9 from the AUR repository (https://aur.archlinux.org/packages/qgis-git/) into the Manjaro box. The compilation and installation went without
> any problem, but when I start, I got the error message as below. The same problem I had with the versions 2.6 and 2.8. Does somebody know the solution for this
> problem?
> Many thanks in advance
> Tomas
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: No module named sip
> Python version:
> 2.7.10 (default, May 26 2015, 04:16:29)
> [GCC 5.1.0]
> QGIS version:
> 2.9.0-Master 'Master', f1817d0
> Python path:
> ['/usr/share/qgis/python', u'/home/tomas/.qgis2/python',
> u'/home/tomas/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
> '/opt/grass/etc/python', '/home/tomas', '/usr/local/lib/python27.zip',
> '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-linux2',
> '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old',
> '/usr/local/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/site-packages']
> Water, taken in moderation cannot hurt anybody.
> -- Mark Twain
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150601/d947e852/attachment.html>
