[Qgis-user] QGIS 2.8.2 dont work grass from processing
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Jun 3 04:45:00 PDT 2015
In order to define the path to R in Processing we had to use the browse-buttons (the one with the three dots which appears when you double click the path-field). Otherwise entered values / changes were not written to registry/QGIS.ini (using OSGeo4W).
Maybe it is the same for GRASS provider...
Cheers
Stefan
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: 3. juni 2015 13:37
To: Jakob Lanstorp
Cc: qgis-user
Subject: Re: [Qgis-user] QGIS 2.8.2 dont work grass from processing
I try to change the setting, without success,
but seeing your attached image, I see that my interface has some different settings.
(i attach an image with my interface)
I see the grass7 has not the path.
Perhaps could be here the issue ?
2015-06-03 13:14 GMT+02:00 Jakob Lanstorp <jlanstorp at gmail.com>:
> Did you setup the GRASS path in menu Processing > Options...
> <http://osgeo-org.1560.x6.nabble.com/file/n5208872/Image2.jpg>
> Jakob Lanstorp
> http://osgeo-org.1560.x6.nabble.com/QGIS-2-8-2-dont-work-grass-from-pr
> ocessing-tp5208851p5208872.html Sent from the Quantum GIS - User
> mailing list archive at Nabble.com.
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
