[Qgis-user] Visible/invisible values
Andreas Neumann
a.neumann at carto.net
Fri Jun 5 06:53:49 PDT 2015
Yes - it is the same issue. So the feature request already exists ...
Andreas
On 05.06.2015 15:52, DelazJ wrote:
> Hi,
> I Can't see the image sent by Giacomo but is it related to this issue
> : hub.qgis.org/issues/11139 <http://hub.qgis.org/issues/11139> ?
> 2015-06-05 15:37 GMT+02:00 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>:
> Hi Giacomo,
> I am cc'ing the list again.
> Now I understand what you want to do. No, it is not possible for
> now. Can you open a feature request at http://hub.qgis.org/ ?
> The "pseudo-layers" for categories in the legend tree are quite
> new and haven't been fully polished for such cases.
> I think it would be a very useful addition, being able to toggle
> all categories of a layer.
> Andreas
> On 05.06.2015 15 <tel:05.06.2015%2015>:33, Giacomo Minotti wrote:
>> please look at the image attached.
>> I have the SHP file with many categories stylized; what can I do
>> to swicht on/off (put or remove the X) in one move?
>> Thanks
>> Giacomo
>> 2015-06-05 14:37 GMT+02:00 Andreas Neumann <a.neumann at carto.net
>> Hi Giacomo,
>> Can you be more precise on what you want to achieve?
>> With your current description I have no idea.
>> Are you talking about symbology? If yes - what renderer are
>> you talking about? Simple, Categorized, Graduated, rule based?
>> Or are you talking about the classes in the legend tree in
>> the "Layers" panel?
>> Andreas
>> On 05.06.2015 14 <tel:05.06.2015%2014>:33, Giacomo Minotti wrote:
>>> Hi all,
>>> is it possible to make visible of invisible all the values
>>> stylized of a shapefile in one move?
>>> I have a SHP file with a lot of values and I'm not able to
>>> swicht on/off all together them.
>>> Thanks
>>> Giacomo
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150605/653faa4f/attachment.html>
