[Qgis-user] What are the limit of number of file fore QGIS-browser?
    Fernando M. Roxo da Motta
    petro at roxo.org
    Sun Jun  7 20:39:57 PDT 2015
On Sun, 7 Jun 2015 12:35:16 +0200, Johan Nilsson <joni8135 at gmail.com>
wrote:
  In Linux you can use the command 'ulimit' to check the limits imposed
to some resources.
$ ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 47429
max locked memory       (kbytes, -l) unlimited
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 95
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) 47429
virtual memory          (kbytes, -v) unlimited
  I am using [Xu|U]buntu 14.04 as well and the limit imposed by the OS
is 1024 simultaneous opened files.
  I don't know if Qgis impose any extra restriction.
  HTH
> Using QGIS 2.9 on Ubumtu 14.04 and qbrowser, but when i open folders
> with many rasters in geotif-format qbrowser halt and close with this
> message in terminal (run qbrowser in terminal)
> (qbrowser.bin:11484): GLib-ERROR **: Creating pipes for GWakeup: Too
> many open files
> Trace/breakpoint trap (core dumped)
> I what to check metadata on the files, seems like the dataset have
> different projections on diffent tif-files. Coordinat referenssystem
> are in tfw-files
> /cheers
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
