[Qgis-user] How to define a region of interest mask in QGIS Processing Model
Paolo Cavallini
cavallini at faunalia.it
Mon Jun 8 08:12:35 PDT 2015
Il 08/06/2015 15:48, Hanssen, Frank ha scritto:
> Yes Bernd, you got it!
> And hmm, that sounds cumbersome ..
Hi Frank,
if a rectangle is enough for you, you can use the extent as an input,
and the user can draw a rectangle on the map.
If you need a polygon, you have to draw it before running the model.
See the attached supersimple example.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
"values": {
"inputs": {
"RASTERLAYER_RESTER": {
"values": {
"pos": {
"values": {
"y": 207.0,
"x": 66.0
"class": "point"
"param": {
"values": {
"isAdvanced": false,
"name": "RASTERLAYER_RESTER",
"showSublayersDialog": true,
"value": null,
"exported": null,
"hidden": false,
"optional": false,
"description": "rester"
"class": "processing.core.parameters.ParameterRaster"
"class": "processing.modeler.ModelerAlgorithm.ModelerParameter"
"EXTENT_ESTENSIONE": {
"values": {
"pos": {
"values": {
"y": 100.0,
"x": 172.0
"class": "point"
"param": {
"values": {
"name": "EXTENT_ESTENSIONE",
"default": "0,1,0,1",
"value": null,
"hidden": false,
"description": "estensione"
"class": "processing.core.parameters.ParameterExtent"
"helpContent": {},
"group": "test",
"name": "test",
"algs": {
"GDALOGRCLIPRASTERBYEXTENT_1": {
"values": {
"name": "GDALOGRCLIPRASTERBYEXTENT_1",
"paramsFolded": true,
"outputs": {
"OUTPUT": {
"values": {
"description": "clip",
"pos": {
"values": {
"y": 359.0,
"x": 683.0
"class": "point"
"class": "processing.modeler.ModelerAlgorithm.ModelerOutput"
"outputsFolded": true,
"pos": {
"values": {
"y": 314.0,
"x": 483.0
"class": "point"
"dependencies": [],
"params": {
"INPUT": {
"values": {
"class": "processing.modeler.ModelerAlgorithm.ValueFromInput"
"EXTRA": null,
"PROJWIN": {
"values": {
"NO_DATA": "0"
"active": true,
"consoleName": "gdalogr:cliprasterbyextent",
"description": "Clip raster by extent"
"class": "processing.modeler.ModelerAlgorithm.Algorithm"
"class": "processing.modeler.ModelerAlgorithm.ModelerAlgorithm"
