[Qgis-user] Question on PostGIS Table and QGIS
Alexandre Neto
senhor.neto at gmail.com
Tue Jun 9 02:22:40 PDT 2015
Hi Randal,
I believe there are a few things going on at the same time here.
When you did
select *, (st_dump(geom)).geom as the_geom from trgtgis.boundary;
you ended up with two geometry columns since trgtgis.boundary.* already
have a geom column(the one with the multipolygons), (can't find a reason to
it's name in qgis are both the_geom tho).
So, instead of using *, you should pick the columns one by one, leaving the
original geometry column out.
Besides that, after using st_dump(), try cast it as the right geometry and
CRS, otherwise QGIS might have problems in guessing. Something like this:
(st_dump(geom)).geom::geometry('POLYGON',26916)
Finally, in order to be able open the layer in QGIS, you need a unique
values primary key, and you can't use the original boundary primary key,
because it has now duplicated values. You can wrap your query and had
a ROW_NUMBER()
OVER() as gid. Something like this:
WITH r as
SELECT
field1,
field2,
field3,--<...>
(ST_Dump(geom)).geom::geometry('POLYGON',26916) as the_geom
FROM
table_1
SELECT
ROW_NUMBER() OVER() as id,
r.*
FROM r;
Finally, if you want to skip all this, you can just select all your
features in QGIS, start editing and use the (very handy cof cof) multipart
split plugin <http://plugins.qgis.org/plugins/splitmultipart/>, it will
split all your multipart polygons into single polygons in the original
layer.
Hope it helps,
Alexandre
On Mon, Jun 8, 2015 at 4:06 PM, Randal Hale <rjhale at northrivergeographic.com
> wrote:
> I've had one other suggestion - I'll add this to the list and see what
> happens. Luckily this isn't vital at the moment - so I have some time to
> play a bit and see what I can do better.
> On 06/08/2015 11:03 AM, Jeff McKenna wrote:
>> On 2015-06-07 11:50 AM, Randal Hale wrote:
>>> I'm breaking new ground and I'm pretty sure this might be a mistake on
>>> my end. I just need to understand why.
>>> I've set up a PostGIS database. I'm importing data through DB manager
>>> into my schema.
>>> I imported some parcel records and discovered that I had multipolygons.
>>> So I decided to break them up into single polygons through the psql
>>> interface:
>>> create table trgtgis.parcels as select *, (st_dump(geom)).geom as
>>> When I go back to QGIS I have two tables called parcels (only one listed
>>> if I look through postgresql). One table is what I suspect to see with
>>> column called the_geom, data Type as Geometry, Spatial type of Polygon,
>>> SRID of 26916. The second parcel table is greyed out and doesn't have a
>>> spatial type or a SRID. Neither lists a primary key (I need to go back
>>> and add one) but I don't think this is the problem...I think.
>>> Screenshot:
>>> https://drive.google.com/file/d/0B8WLtz606XDdcFIxaG5fNExpMlU/view?usp=sharing
>> Hi Randy,
>> I've seen this issue before (QGIS listing multiple layers for one PostGIS
>> table), but I did solve it, I just can't remember how I did that ha :)
>> I believe one of my issues was that QGIS (and MapServer in fact) need a
>> unique ID field, to display the data from PostGIS, so I always make sure to
>> specify a unique ID field when creating tables for use in both QGIS and
>> MapServer.
>> -jeff
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale http://about.me/rjhale
> http://www.northrivergeographic.com/introduction-to-quantum-gis
> Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150609/7a57a351/attachment.html>
