[Qgis-user] Issue installing QGIS 2.8 64 bit on Windows 8.1 - it defaulted to the administrative user
Peter Cooper
peter at pcooper.me.uk
Mon Jun 15 11:44:24 PDT 2015
Thanks. Uninstalling, and reinstalling as Admin user seems to solve it. Now I can get on!
Peter
Sent: Monday, June 15, 2015 12:13 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Issue installing QGIS 2.8 64 bit on Windows 8.1 - it defaulted to the administrative user
I am assuming you are using the QGIS easy installer and not the OSGEO installer. It is good practice to login as admin in Windows to install any software. In theory, you can do it from any account but you will be asked for the admin password (but this will sometime give problems). If you are not asked for a password, maybe something went wrong. I would uninstall QGIS and try again with a new downloaded installer. If this fails, try the OSGEOW4 installer using the standard desktop option.
Unless you specify differently, any user can run QGIS from any account, admin or not. If you have accents in your account name (like é), you could have problems with some plugins.
QGIS is always installed with a number of software like Grass, Saga... You can delete the short cuts from the desktop but, as you become more proficient in QGIS, they will become handy. You can't delete the softwares.
The OSGEO4W Shell, for example will permit you to use GDAL directly from the command line. You could do this directly from the windows command prompt but you would need to change your system variable individually to make sure Windows find the gdal software libraries and all it's dependencies. The OSGEO4W DOS prompt does that for you.
Good luck
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jun 15, 2015 12:00 AM, "Peter Cooper [via OSGeo.org]" <[hidden email]> wrote:
I have 64 bit windows 8.1, and 2 users – an administrative user and a non-administrative one.
As I normally do for installations, I used the non-administrative user to download and install the QGIS Standalone installer version 2.8 64 bit. It seemed to install OK except that it was installed for the administrative user (without asking me for any password). I only realised this when I could not get it to work from the desktop of the user I had installed it in, and saw that the sample data had been installed into the Documents folder of the administrative user.
Do I have to keep using it from my administrative user? Did I miss this bit of the installation documentation?
By the way I was a little confused to start with by all the new icons that appeared on my desktops, and I am assuming I can ignore all but one:
a.. 3 on all desktops: MSYS, SAGA GIS (2.1.2), OSGEO4W Shell
b.. plus 3 just on the administrative user’s desktop: GRASS GIS 6.4.3, QGIS Browser 2.8.2, QGIS Desktop 2.8.2
Now I have found how to run it I am looking forward to exploring QGIS for my own uses. Thanks to everyone who has contributed to it.
Peter C
Qgis-user mailing list
<a href="/user/SendEmail.jtp?type=node&node=5210913&i=0">[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Issue-installing-QGIS-2-8-64-bit-on-Windows-8-1-it-defaulted-to-the-administrative-user-tp5210913.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click here.
<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml" style="font:9px serif">NAML
View this message in context: Re: Issue installing QGIS 2.8 64 bit on Windows 8.1 - it defaulted to the administrative user
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150615/05bd8a2e/attachment.html>
