[Qgis-user] QGIS Composer: exported image doesn't have the world file
    Andreas Neumann
    a.neumann at carto.net
    Thu Jun 18 02:49:24 PDT 2015
ah - it seems like most people aren't aware that this is now defined in
the composition properties - at least I wasn't aware of it. Maybe it is
disabled by default - esp. for people who have old QGIS properties from
older versions.
All seems fine then. Just use this setting and it should work.
Andreas
On 18.06.2015 11:46, Nyall Dawson wrote:
> On 18 June 2015 at 19:41, Salvatore Larosa <lrssvtml at gmail.com> wrote:
>> Hi,
>> On Thu, Jun 18, 2015 at 11:23 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>> Il 18/06/2015 11:19, Andrea Peri ha scritto:
>>>> Hi,
>>>> it was a work funded ByRegione Toscana in the last qgis 2.1
>>>> http://hub.qgis.org/issues/6985
>>>> https://github.com/qgis/QGIS/pull/658
>>>> We also fund the capability di generate the tfw using the atlas from composer.
>>>> I agree that this a fundamental feature for a profession use of qgis.
>>> If confirmed, it's a regression, thus a blocker.
>> maybe I am missing something here, but
>> I can to export a map layout from composer with the world file, with
>> map, legend etc
> I also can't confirm - it's working fine here.
> Nyall
> Qgis-user mailing list
