[Qgis-user] Once again mdb files on Linux.
Fernando M. Roxo da Motta
petro at roxo.org
Fri Jun 19 07:40:04 PDT 2015
Hi all,
Has someone tried to load MDB file on QGIS in Linux lately?
I went through this list history and read a lot about people trying
to load this kind of data in QGIS and failing. So far the impression
I have is that it is only feasible using Windows 32 bits. I don't
remember to read a single case of success in Linux.
I am trying to follow the instructions from many messages, in many
lists, in many languages without success.
I am running [Xu|U]buntu 14.04.2 LTS 64 bits, with QGIS 2.8.2 64 bits
from QGIS repository (using apt-get). I have installed mdbtools,
odbc-mdbtools and unixodbc, everything with 64bits.
I have the following configurations:
$ cat /etc/odbcinst.ini
[MDBTools]
Description = MDBTools Driver
Driver = libmdbodbc.so
Setup = libmdbodbc.so
FileUsage = 1
UsageCount = 1
$ cat .odbc.ini
[Limites]
Description = Something to test
Driver = MDBTools
Database = ~/gis/dados/Meus/MDB/Limites.mdb
Host =
Port =
User =
Password =
Trace = Yes
TraceFile = /tmp/Limites.log
$ odbcinst -q -s
[Limites]
$ isql Limites
| Connected! |
| sql-statement |
| help [tablename] |
| quit |
SQL>
If I try a number of queries it seems to work.
If someone wnt to give it a try, the Limites.mdb file was obtained at:
ftp://geoftp.ibge.gov.br/mapeamento_sistematico/base_vetorial_continua_escala_250mil/Limites.zip
Ogrinfo, _in_principle_, as support for ODBC and PGeo:
$ ogrinfo --formats|grep 'PGeo\|ODBC'
-> "ODBC" (read/write)
-> "PGeo" (readonly)
$ ogrinfo PGeo:Limites
ERROR 1: PGeo: MDB Tools driver not found!
Warning 1: Unable to install MDB driver for ODBC, MDB access may not
supported.
supported.
FAILURE:
Unable to open datasource `PGeo:Limites' with the following drivers.
======= long list clipped ==========8<---------------
$ ogrinfo ODBC:Limites
geometry_columns is not a table in this database
Got no result for 'SELECT f_table_name, f_geometry_column,
geometry_type FROM geometry_columns' command INFO: Open of
`ODBC:Limites' using driver `ODBC' successful.
In QGIS I tried to load using "insert vector layer->database" and
tried to configure two types of connections 'ESRI Personal GeoDatabase'
and 'ODBC'. In both I configured just a name and a DSN from ODBC.
The test for Personal GeoDatabase failed but for ODBC succeeded. But
when trying to load using ODBC connection it fail saying that
ODBC-Limites is not a recognized data source.
One interesting thing (IMHO) is that if I insert the path for the MDB
file when trying the Personal GeoDatabase configuration the error in
QGIS reads:
Connection failed - Check settings and try again.
Extended error information:
Unable to initialize ODBC connection to DSN for
~/gis/dados/Meus/MDB/Limites.mdb, [unixODBC][Driver Manager]Data source
name not found, and no default driver specified
If I use just the DSN of the '~/.odbc.ini' the error reads:
After all this, is there anything else worth a try?
TIA
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
( Usuário Linux registrado #39505 ) | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
