[Qgis-user] Issues with Global Soil Data netCDFs in QGIS & GDAL
    Michael Treglia
    mtreglia at gmail.com
    Fri Jun 19 09:21:11 PDT 2015
Quick follow-up - Just tried importing one of these problematic layers into
stand-alone SAGA (version 2.1.3, x64), which worked. (Only problem was the
projection was flipped upside-down) - interesting as it was via the 'GDAL:
Import NetCDF' tool.
And the gdal version I was using (from previous e-mail) is GDAL 1.11.2
Any thoughts on this are appreciated - thanks again!
mike
On Fri, Jun 19, 2015 at 11:02 AM, Michael Treglia <mtreglia at gmail.com>
wrote:
> Hi All,
> I'm trying to work with the Global Soil Dataset for Earth System Modeling
> (available at: http://globalchange.bnu.edu.cn/research/soilw) and having
> mixed success with the netCDF files - wanted to get any thoughts from folks
> here as I'm pretty new to working with this format, and running into some
> issues.
> I'm primarily working with the 8-layer files (which are split into two
> 4-band files each; each band represents a different horizon). I'm able to
> load netCDFs of some layers (in particular 'gypsum', 'CaCO3', and 'Total
> Carbon') without issue (using QGIS 2.8 - both import raster and via the
> netCDF viewer plugin). And running gdalinfo from the command line returns
> the metadata without issue.
> However, I've also been trying to work with Sand, Silt, Clay, and Gravel
> Content (as % by weight), and not having any success in QGIS - the netCDF
> files aren't recognized by the netCDF viewer, and can't be pulled in via
> 'import raster'. Also,  gdalinfo returns the following error:
> ERROR 4: `SAND1.nc' not recognised as a supported file format.
> I am able to read these data using R - most simply, using the 'raster'
> package (sample code below), and I can also get the info using ncdf and
> ncdf4 packages:
> library(raster)
> brk <- brick("[file name.nc]", varname="[variablename]")
> #Can plot using
> plot(brk) #plots all 4 layers from netcdf
> plot(brk[[1]]) #Plots only first layer from netcdf
> But, I'm trying to do this in QGIS or via gdal utilities for speed  - R is
> slow for this (may be ways to speed it up, but haven't toyed with it much).
> I'd appreciate any ideas on what might be contributing to these issues -
> thanks in advance for any input!
> Mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150619/ce8b6580/attachment.html>
