[Qgis-user] QGIS crashes when zooming out from MS SQL layer
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Jun 22 01:36:40 PDT 2015
I have a View in MS SQL containing some point data (263 points) and a int64 primary key (qlonglong data type in QGIS), which I have loaded to QGIS (CRS: 4326, no OTF-projection).
When I zoom out, QGIS crashes at a certain zoom level. "Zoom to layer" crashes every time I try. This happens both in master and 2.8.2.
When I export the layer to shape, the resulting file alone works just fine (some data types in the attribute table were converted)...
Both layers (shape and MS SQL) have exactly the same spatial extent.
I tried to compare the number of features in the MS SQL layer and the shape layer. "Count features" did not work for the MS SQL layer, but number of entries in the attribute table are the same...
Any ideas? Should I file a ticket?
Thanks for helping.
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150622/c789b3e5/attachment.html>
