[Qgis-user] Line symbol behavior OR how to use chainage
Thomas Schweser
tschefski at gmx.de
Tue Jun 23 12:37:01 PDT 2015
Hi Nyall,
thanks for your reply. I found your solution in QGIS-Version 2.9.0-Master.
kind regards
Am 21.06.2015 um 00:50 schrieb Nyall Dawson:
> On 20 Jun 2015 20:46, "Thomas Schweser" <tschefski at gmx.de
> <mailto:tschefski at gmx.de>> wrote:
>> Hi
>> I'm using QGIS 2.6 on win 7.
>> When editing a line element I used an Marker line with a Simple marker
>> (vertical line). I can edit the interval i.g. 5000 mm. I thought this
>> would be usefull for some kind of chainage - line element is an cable
>> and it should have a chainage. But the problem is when zooming in the
>> marker changes its geogrphical position. Position on monitor is somehow
>> fix. Is there a way to change this behavior?
> I can't remember if I added it in 2.8 or 2.10, but there's an option
> under the advanced menu for disabling this automatic line clipping to
> the canvas extent. That should do what you want.
> You'll need to upgrade though!
> Nyall
>> For my cable-chainage I found a plugin - chainage. Works fine but I
>> didn't find a way to adjust the markers to my line element (the cable).
>> The markers should be vertical to the line but the lable I like to have
>> horizontal.
>> Thanks for any help!
>> Thomas
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
