[Qgis-user] Not able to connect to Oracle via ODBC
    Tudorache, Marian
    Marian.Tudorache at navcanada.ca
    Thu Jun 25 14:03:45 PDT 2015
Hello,
What I am trying to do: Add a vector layer from an remote Oracle database.
Description:
I tried to add a vector layer using ODBC connectivity to an Oracle database on QGIS 2.8.2.
Add vector Layer
Choose Database
Type ODBC
Click New
I filled the form as:
Type ODBC
Host: ssfdata
Database: CAAR
Port: 1521
Username: USER
Password: PASS
When I clicked Test Connection I got:
Connection failed - Check settings and try again
Extended error information:
Unable to initialize ODBC connection to DSN for USER/PASS at CAAR,
[unixODBC][Driver Manager] Datasource name not found, and no default driver specified
I opened a terminal window and I typed:
Isql -v caarODBC
I was able to connect to my database
| Connected            |
| sql -statement     |
| help [tablename] |
| quit                       |
SQL>
So the unixODBC driver works for the database but QGIS is not able to access via ODBC.
Is any special settings related qgis to make ODBC working?
Thanks,
marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le pr?sent message ?lectronique et tout fichier qui peut y ?tre joint peuvent contenir des renseignements privil?gi?s ou confidentiels destin?s ? l'usage exclusif des personnes ou des organismes ? qui ils s'adressent. Si vous avez re?u ce message ?lectronique par erreur, veuillez en informer l'exp?diteur imm?diatement et supprimez le. Toute reproduction, divulgation ou distribution du pr?sent message ?lectronique est strictement interdite. NAV CANADA n'assume aucune responsabilit? en cas de dommage caus? par tout virus ou autre programme malveillant transmis par ce message ?lectronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150625/a34ff867/attachment.html>
