[Qgis-user] SQL query for style
    Lester Anderson
    arctica1963 at gmail.com
    Fri Jun 26 05:38:28 PDT 2015
It is the categorised / graduated render I was looking at. I could not
figure out the correct SQL expression for the column section; how would
this expression be written here?
eg Find all values where Z6=0 and render Z1 for the symbology associated
with that particular Z6 value
Cheers
Lester
On 26 June 2015 at 13:22, Andreas Neumann <a.neumann at carto.net> wrote:
>  Hi Lester,
> You can either use an expression which uses more than one column (for
> graduated or categorized renderer) or the rule based renderer mentioned by
> Carlos, which is more powerful.
> Andreas
> On 26.06.2015 12:57, Lester Anderson wrote:
>     Hi,
>  I have a point database loaded with columns Z1 to Z6, where Z6 has values
> 0,0.5 and 1. What I am trying to do with the symbology is just to get it to
> plot and colour the depths (Z1) only where Z6=0
>  Can this be done from the style option for the layer?
>  So what I want to do is:
>  IF Z6=0 PLOT Z1
>  Sure this is very simple but can't see it :)
>  Cheers
>  Lester
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/c6293d8f/attachment.html>
