[Qgis-user] Missing Oracle connectivity on QGIS Browser
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Fri Jun 26 06:55:47 PDT 2015
Hi Andreas,
Do you still follows this thread?
I have tested the oracle client on my machine and it does work.
I am able to connect to Oracle from a terminal windows using either isql or sqlplus.
One thing that I found and it is related to Red Hat.
When I tested the if all dependencies are working for libsqora.so.11.1 running the command bellow
ldd /usr/lib/oracle/11.2/client64/lib/libsqora.so.11.1
I got libodbcinst.so.1 => not found
I have fixed this issue by creating a symbolic link from /usr/lib64/libodbcinst.so.1 to /usr/lib64/libodbcinst.so.2.
This fix made the unixODBC workable from a terminal windows and other applications which use ODBC connectivity but QGIS still does not have Oracle connectivity icon and it is not able to create an Oracle connection.
Is this a QGIS bug?
Thanks,
Marian
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: June-18-15 4:53 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Missing Oracle connectivity on QGIS Browser
Hi Marian,
Do you already have an Oracle client on this machine? Note that QGIS on Linux does not provide an Oracle client like it does on the Windows version. You would have to install the Oracle client yourself and make sure it is in the LIBRARY Path and that ORACLE_HOME is defined and the name resolution (tnsnames.ora or similar mechanisms) work fine.
Have a look at the Oracle documentation on how to install the Oracle client on Linux. I think the instant client is enough - you don't need the full client.
Andreas
On 18.06.2015 22:13, Tudorache, Marian wrote:
> Hi,
> I have installed the latest QGIS 2.8 Wien on Linux Red Hat 7 and I do not see the Oracle Connectivity icon in.
> I have MSSQL, SpatialLite, PostGIS, OWS, WCS, WFS, WMS.
> I sued to have it on Windows version of QGIS.
> Can someone help me how to install it?
> Thanks,
> Marian
> This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
