[Qgis-user] Default values in form
Jürgen E. Fischer
jef at norbit.de
Fri Jun 26 07:20:50 PDT 2015
Hi Didier,
On Fri, 26. Jun 2015 at 10:08:12 +0200, didier peeters wrote:
> Simple question : is there a way to set a default value for an attribute in
> QGis ?
> I have Postgis layers in QGis in which I’m inserting or updating data, and I
> would like that some fields would be filled automatically unless I fill them
> myself. Well that’s the definition of a default value, and I don’t think
> that using layers stored in Postgis would make any difference.
If the column has default values in postgis they will already be used as
default value in the form.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/0811d589/attachment.sig>
