[Qgis-user] Default values in form
didier peeters
dpeeter1 at ulb.ac.be
Sun Jun 28 00:55:13 PDT 2015
Hi Andreas,
it would be nice to have these options:
by default the default values precede the last inserted values (otherwise defining default values would be somehow useless), except where specified otherwise in the field definitions. So there would be an option in each field definition (a checkbox, next to the default value definition field) stating that the last non null inserted values do precede the default one.
Cheers,
Didier
> Le 26 juin 2015 à 14:15, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi,
> When doing anything with "default" values we also have to think about the option we have which automatically fills in the values of the last inserted record.
> Which one has precedence? The default value or the value of the last record?
> Also - I think we probably need a mixture of default values and values from the last record - but I think the values of the last record are not fine-grained enough - so we could tell QGIS to use the values from the last record for some columns but for other columns use the default value.
> We have to think about both approaches and need a collaboration of both, in my opinion.
> Andreas
> On 26.06.2015 12:14, didier peeters wrote:
>> Thanks,
>> I’ll surely take a look at your plugin, and open a ticket if necessary.
>> @Stefan : I had seen that post by Nathan Woodrow, but was hoping for something ‘lighter’ …
>> Didier
>>> Le 26 juin 2015 à 11:32, Bernhard Ströbl <bernhard.stroebl at jena.de> a écrit :
>>> Hi,
>>> if you define the values as default in PostgreSQL and use my :) plugin DataDrivenInputMask [1] these values are inserted in the mask that is created by the plugin in QGIS. Thus for fields with defaults you cannot insert NULL vallues (but that's why you define a default).
>>> Bernhard
>>> http://plugins.qgis.org/plugins/DataDrivenInputMask/
>>> Am 26.06.2015 um 10:08 schrieb didier peeters:
>>>> Hello,
>>>> Simple question : is there a way to set a default value for an attribute in QGis ?
>>>> I have Postgis layers in QGis in which I’m inserting or updating data, and I would like that some fields would be filled automatically unless I fill them myself. Well that’s the definition of a default value, and I don’t think that using layers stored in Postgis would make any difference.
>>>> Thanks
>>>> Didier
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> __________ Information from ESET Mail Security, version of virus signature database 11847 (20150626) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> Didier Peeters
>> Institut de Gestion de l'Environnement et d'Aménagement du Territoire (IGEAT)
>> Université Libre de Bruxelles (ULB)
>> CP130/03
>> av. F. D. Roosevelt 50
>> B-1050 Bruxelles
>> Tél : +32-2-650 68 17
