[Qgis-user] Qgis 2.10 - Pisa - Todau update.
Fernando M. Roxo da Motta petro at roxo.org
Mon Jun 29 08:44:32 PDT 2015
  Hi all,
  Today the update of my installation offered the QGis 2.10 for
update.  I have installed it, and all the corresponding package
entourage.
  I am using a [Xu|U]buntu 14.04.2 64 bits and the Apt source is
defined as:
deb http://qgis.org/debian trusty main
  I don't know if this is the better place to publish any issue before
I open a ticket.  I prefer to see if any one else are having the same
issues I am.
  First of all, the start up of this new version looked blazing fast
compared to 2.8, absolutely amazing!  Rven the opening of a loaded
project seemed much faster than before.
  When I went to the official repository for plugins update, none was
updated and only one was flagged as invalid, the Contrast homogenizer
that is registered as supporting up to 2.9 version.
  The only issue I got so far was about the feature information.  When
I tried to identify a big polygon (~100sqkm) it says that "no feature
found at this position", although a zoom to layer knows the position
and extent of the polygon.
  The project was originally in an UTM SRC and I tried to change to
WGS84 at no help.   I changed it to WGS84 Pseudo Mercator and failed
again.    Just started clicking randomly around a polygon when an
information window popped up.
  Trying to understand where and why it worked I figured out that the
information only worked if the click is close to one of its points,
no need to be a vertex.
  The same hold for line features as well, only close to one of its
points the feature information window pops up.
  BFN
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
