[Qgis-user] Feature limit for GetFeatureInfo in adding WMS not editable since qgis 2.2
Reiche, Andreas Andreas.Reiche at lgln.niedersachsen.de
Mon Jun 29 23:00:00 PDT 2015
Moin Jürgen,
thanks for fixing. In which release will this patch be integrated?
Mit freundlichen Grüßen
Andreas Reiche
Landesamt für Geoinformation und Landesvermessung Niedersachsen (LGLN)
- Landesvermessung und Geobasisinformation - Landesbetrieb -
Fachgebiet 223 - Wertermittlungsinformation, Geschäftsnachweise, KLR
Podbielskistraße 331, 30659 Hannover
mailto:andreas.reiche at lgln.niedersachsen.de
www.lgln.niedersachsen.de
Moin Andreas,
On Mon, 29. Jun 2015 at 10:53:21 +0000, Reiche, Andreas wrote:
> Hi, i'm brand new to the user list and relatively new to Qgis.
> I noticed the following problem when adding a WMS to a project.
> There is an option to set the feature limit for GetFeatureInfo requests when using a WMS. This results in setting the FEATURE_COUNT param in the request itself.
> When I started with Qgis 1.8 everything goes fine. But since Version 2.2 (to which I switched) up to 2.8.1 (where I'm now) I'm not able to change this value.
> The field in the UI is greyed out. The value is 10 and I'm not able to change it.
> I'm in need to increase this value for our own WMS'es.
> I already searched the mailing list and the bug tracker but couldn't find any related stuff.
> So is this just a configuration option which I don't know of?
> Or is it a bug?
> Btw, I'm on a Win 7 box.
Fixed in 1dfe005[1]
Jürgen
[1] https://github.com/qgis/QGIS/commit/1dfe005e67162bd1950397940de4f0008512f9c0
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
