[Qgis-user] Qgis 2.10 - Pisa - yesterday update is ok.
    Fernando M. Roxo da Motta
    petro at roxo.org
    Tue Jun 30 04:59:15 PDT 2015
On Mon, 29 Jun 2015 21:24:01 -0300, "Fernando M. Roxo da Motta"
<petro at roxo.org> wrote:
  Just to let you know.
  For some reason I have re-checked the problems today and they
vanished.   I really don't know what happened yesterday, I can't even
explain is as a PEBKAC (http://catb.org/jargon/html/P/PEBKAC.html), I
really can't figure out what happened.
> On Mon, 29 Jun 2015 12:44:32 -0300, "Fernando M. Roxo da Motta"
>   Just to let you know, for raster and point layers the feature
> identification is working as usual.
> >   Hi all,
> >   Today the update of my installation offered the QGis 2.10 for
> > update.  I have installed it, and all the corresponding package
> > entourage.
> >   I am using a [Xu|U]buntu 14.04.2 64 bits and the Apt source is
> > defined as:
> > deb http://qgis.org/debian trusty main
> >   I don't know if this is the better place to publish any issue
> > before I open a ticket.  I prefer to see if any one else are having
> > the same issues I am.
> >   First of all, the start up of this new version looked blazing fast
> > compared to 2.8, absolutely amazing!  Rven the opening of a loaded
> > project seemed much faster than before.
> >   When I went to the official repository for plugins update, none
> > was updated and only one was flagged as invalid, the Contrast
> > homogenizer that is registered as supporting up to 2.9 version.
> >   The only issue I got so far was about the feature information.
> > When I tried to identify a big polygon (~100sqkm) it says that "no
> > feature found at this position", although a zoom to layer knows the
> > position and extent of the polygon.
> >   The project was originally in an UTM SRC and I tried to change to
> > WGS84 at no help.   I changed it to WGS84 Pseudo Mercator and failed
> > again.    Just started clicking randomly around a polygon when an
> > information window popped up.
> >   Trying to understand where and why it worked I figured out that
> > the information only worked if the click is close to one of its
> > points, no need to be a vertex.
> >   The same hold for line features as well, only close to one of its
> > points the feature information window pops up.
> >   BFN
> >   Roxo
>   Roxo
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
