[Qgis-user] Where is SAGA's polygons intersection
Carlos Cerdán
sig.upagu at gmail.com
Mon Mar 2 05:37:10 PST 2015
Thank you very much André, I will wait for QGIS 2.8 for use it on
Windows... if this issue is fixed.
On Ubuntu this issue is fixed by unchecking "Use SAGA 2.0.8 syntax". Go to
Processing --> Options --> Provider? (In spanish it says "proveedor") -->
Saga.
On Windows there isn't this option, so SAGA polygon intersection is not
activated.
Regards from Perú
Carlos
As I said, my QGIS 2.6 on Ubuntu (14.04 also) is OK, and
2015-02-28 1:12 GMT-05:00 Andre Joost <andre+joost at nurfuerspam.de>:
> Am 27.02.2015 um 18:59 schrieb Carlos Cerdán:
> I want to use SAGA Intersection tool from processing in QGIS 2.6, under
>> Windows 7, but it doesn't appear in list of processing modules. Checking
>> SAGA directly, I can see this tool under Modules --> Shapes --> Polygons
>> --> Polygon intersection. It has another name in QGIS processing?
> Same here, and it is missing on ubuntu 14.04 also (QGIS 2.6.1 from
> ubuntugis unstable).
> But if you install the latest qgis-dev from osgeo4w, you get Shapes -
> Polygons - Intersect, as well as some other algorithm interfaces that are
> not in original SAGA. So it might be worth to wait for the upcoming QGIS
> 2.8.
> HTH,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150302/39564cd0/attachment.html>
