[Qgis-user] Transferring QGIS work when you used a PostGIS database
Alex Mandel tech_dev at wildintellect.com
Wed Mar 4 22:29:24 PST 2015
On 03/04/2015 09:20 PM, Leahy, Thomas A. wrote:
> Hello,
>    If I just use shape and raster files it is fairly easy for me to give someone all my QGIS work on a USB stick as it uses relative directory references as long as everything is below the Project Directory they can use it as I did. However if I decide to use PostGIS is there an easy way to similarly transfer the work that was done to another person?
>     Thanks for your assistance,
>     Tom Leahy
Convert the Postgis db to Spatialite. There are several tools out there
for this, ogr2ogr would work, as would a couple of QGIS Plugins (offline
editor can clone your postgis to local), the spatialite author even made
some tool I can't recall the name right now.
Eventually this will be the role of the new GeoPackage format that will
bundle vector and raster into a sqlite db.
Thanks,
Alex
