[Qgis-user] Transferring QGIS work when you used a PostGIS database
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Mar 5 10:30:52 PST 2015
If you are transferring your database to the same or newer version of
Postgresql then generally: yes. But take some precautions:
  * In the original database: Don't use schema public to store data;
    create another schema for that purpose. The reason for this action
    is to separate all the postgis functions and view - which resides in
    schema "public" - from ordenary data.
  * When you make a backup: Only backup your data schema (not public).
    This means, that you won't get any version specific, postgis related
    stuff into your backup.
  * When you restore the backup in another database: First create the
    PostGIS extension in this database with the command "Create
    extension postgis". This will create the PostGIS extension in the
    new database. Secondly: restore your backup. This will restore the
    data schema in the database.
If the source and target database system resides on two computers with
the same operating system and same postgres and postgis version, the
above procedure is not needed. Simply make a backup of the source
database and restore it on the target computer.
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 05-03-2015 kl. 16:57 skrev Andre Joost:
> Am 05.03.2015 um 13:01 schrieb Rémi Cura:
>> The equivalent way, that is also the simplest, is to dump the tables
>> (and
>> related functions/triggers if necessary) into a file, then restore the
>> table in the target postgis database!
> Does this work if the users are on different OS, like
> Windows/Linux/Mac OSX, 32bit or 64bit, or maybe different
> PostgreSQL/Postgis versions?
> greetings,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150305/21de60aa/attachment.html>
