[Qgis-user] batch conversion of raster file to GeoTIFF format
    Ramon AndiƱach
    custard at westnet.com.au
    Thu Mar  5 20:19:13 PST 2015
Hi Leo,
I can't help you with why it isn't working as a batch, but:
1. Yes, the GDAL script at the bottom of the window should be expected to work in the OSGeo shell.
2. There's probably an equivalent in Processing, which might give you a better response.
-ramon.
> On 6 Mar 2015, at 11:02, Leo Kris Palao <lk.palao at gmail.com> wrote:
> Hi QGIS users,
> I am having a problem converting my 539 raster files to GeoTIFF format. I tried using the GDAL Translate option in the Processing Toolbox but it reads only the *.hdr file of my raster not the file that holds my raster data. When I execute the batch process file using file.hdr as my input it returns:
>> Processing of the following files ended with error:
>> ERROR 1: The selected file is an ENVI header file, but to
>> open ENVI datasets, the data file should be selected
>> instead of the .hdr file. Please try again selecting
>> the data file corresponding to the header file:
>> J:/MODIS_EVI_smooth/mod_2002345_EVI_smth.hdr
> I cannot find the appropriate file type option when selecting which files to load as my inputs. Even thought I select files(*.) type option, still I cannot find my files in my directory.
> I have also tried to load the file.hdr and later remove the *.hdr extension before executing the batch process but with no success.
> This is the sample file that I am working on:
>> mod_2002345_EVI_smth................File...................45,000KB
>> mod_2002345_EVI_smth.hdr.......... HDR.................1KB
>> mod_2002345_EVI_smth.sml..........SML File............3KB
> I have successfully converting one raster file using Translate module under Raster > Conversion > Translate but I can only process one at a time. But I don't want to do this for my remaining raster data. Please also note the I have tried the batch mode but with no success.
> I copied the GDAL script (below) and I wonder if I can run a batch processing of this script in OSGeo Shell. Just my guess.
>> gdal_translate -a_srs "+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181 +b=6371007.181 +units=m +no_defs" -a_nodata -3000 -of GTiff J:/MODIS_EVI_smooth/mod_2002345_EVI_smth J:/MODIS_EVI_smooth_TIFF/mod_2002345_EVI_smth.tif
> Can you help me with this.
> Thanks,
> -Leo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150306/39a2840b/attachment.html>
