[Qgis-user] Fwd: Visualize Distance matrix
Alexandre Neto senhor.neto at gmail.com
Tue Mar 10 02:32:06 PDT 2015
If your data is in a Spatialite or a Postgis database, it's quite easy to
achieve what you seek.
All you need to do is create a SQL query similar to this one in DB Manager:
SELECT
    a.gid as dep_id,
    b.gid as dest_id,
    ST_Distance(a.geom, b.geom) as distance,
    ST_MakeLine(a.geom, b.geom) as geom
FROM
    my_table as a, my_table as b
WHERE
    a.gid > b.gid
Note: This is the postgis version, not sure if the same function applies to
spatialite
Add it to the map canvas by using dep_id as unique value column and geom as
geometry column.
Hope it helps.
Alexandre Neto
On Tue, Mar 10, 2015 at 8:08 AM, Raymond Nijssen <r.nijssen at terglobo.nl>
wrote:
> Hi Joris,
> I dont know about that plugin, but i would write a little script for that
> like this:
> # get active (point) layer as input
> inputlayer = iface.activeLayer()
> # create new memory layer for output
> outputlayer = QgsVectorLayer("Linestring", "distance_lines", "memory")
> outputprovider = outputlayer.dataProvider()
> # loop all points
> iter = inputlayer.getFeatures()
> for feature in iter:
>     p1 = feature.geometry().asPoint()
>     iter2 = layer.getFeatures()
>     for feature2 in iter2:
>         p2 = feature2.geometry().asPoint()
>         if not p1 == p2:
>             # create new line
>             l = QgsGeometry.fromPolyline([p1,p2])
>             feat = QgsFeature()
>             feat.setGeometry(l)
>             outputprovider.addFeatures([feat])
> outputlayer.commitChanges()
> outputlayer.updateExtents()
> # add to map
> QgsMapLayerRegistry.instance().addMapLayer(outputlayer)
> Good luck,
> Raymond
> On 09-03-15 18:18, Joris Hintjens wrote:
>> Thanks Raymond, but what I need is the distance from every point in a
>> layer to every other point. That is what “distance matrix” gives me.
>> Then, I want to plot every distance line (as a seperate layer?) on the
>> map.
>> Joris
>>  Begin doorgestuurd bericht:
>>> Datum: 9 maart 2015 15:53:56 CET
>>> Van: Raymond Nijssen <r.nijssen at terglobo.nl>
>>> Aan: qgis-user at lists.osgeo.org
>>> Onderwerp: Antw.: [Qgis-user] Visualize Distance matrix
>>> Hi Joris,
>>> Not sure if I understand your question, but if you want to do a distance
>>> calculation for all points in a point layer to a certain location you can
>>> use the field calculator in the attribute table window.
>>> The expression should be:
>>> distance($geometry ,geomFromWKT( 'POINT(0 0)' ))
>>> to calculate all distances to coordinate 0,0.
>>> Hope this helps you.
>>> Raymond
>>> On 09-03-15 15:13, Joris Hintjens wrote:
>>>> I feel stupid: I am stuck with what seems a basic operation..
>>>> I have a points layer, of which I want to visualize the distance matrix.
>>>> I can create the martini CSV.
>>>> I cannot create a distance hub layer with the MMQGIS plugin with From
>>>> and To point from within  the same layer.
>>>> Any help on how I ca get this result on my map?
>>>> PoinA——————>PointB
>>>>                 xxx Meter
>>>> and this for the entire matrix
>>>> thanks
>>>> Joris
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Terglobo
>>> Ampèrestraat 110
>>> 5223 CT 's-Hertogenbosch
>>> 06-25314983
> Terglobo
> Ampèrestraat 110
> 06-25314983
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150310/4df8c53e/attachment.html>
