[Qgis-user] GRASS dependency problem on OS X
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Mar 10 06:25:48 PDT 2015
Does it allow you to turn on GRASS in Processing?  If so, you can see what the actual error is in the algorithm output when you try to run one if you turn on the Processing option to leave windows open when done.
On Mar 9, 2015, at 11:47 PM, Howard Frederick <simbamangu at gmail.com> wrote:
> Frustrating and inconsistent problem with GRASS dependency in QGIS 2.8 (and 2.6 before upgrading).
> I get the usual “unmet dependency” error when trying to run any GRASS tool - but the Options link correctly to the location of the grass folder inside QGIS.app.
> I have done a clean install, removing the preferences (org.qgis.QGIS2.plist), the .qgis2 folder and anything else I could find, but the problem persists.
> The puzzle: on the same machine, if I create a new user and log in, GRASS tools run just fine in QGIS, with no modifications of the Processing configuration! Seems there is some configuration file that is messing with things - or possibly a path setting?
> Any suggestions as to what I could look for?
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
