[Qgis-user] building qgis 2.8.1 against grass 7
José Antonio Barreña Cayuela
jabarcay at gmail.com
Wed Mar 11 16:09:13 PDT 2015
In my case, I have the same problem when compiling qgis with grass 7
preinstalled
El 11/03/15 a las 18:27, Donovan Cameron escribió:
> Morning,
> I'm attempting to compile the QGIS 2.8.1 grass plugin against GRASS
> 7.0.0 on Arch Linux 64bit.
> I read somewhere (maybe GIS.se?) that the GRASS plugin in QGIS doesn't
> have full functionality and a kickstarter/crowdfunding process could
> be underway to get it up to par, but in the meantime it was also
> mentioned it's still possible to use the toolbar to load grass 7
> layers into the qgis canvas.
> GDAL 1.11.2 is installed and so is gdal-grass plugin using some
> patches to get GDAL working with grass 7.
> I'm using the following cmake options in the QGIS build:
> -DWITH_GRASS=ON
> -DGRASS_PREFIX=/opt/grass
> -DGRASS_INCLUDE_DIR=/opt/grass/include
> But QGIS fails to build with the following error:
> Scanning dependencies of target qgisgrass
> [ 50%] Building CXX object
> src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp: In static
> member function ‘static void QgsGrass::setMapset(QString, QString,
> QString)’:
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:383:51:
> error: ‘G__setenv’ was not declared in this scope
> G__setenv( "GISDBASE", gisdbase.toUtf8().data() );
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:392:30:
> error: ‘G_available_mapsets’ was not declared in this scope
> ms = G_available_mapsets();
> member function ‘static QString QgsGrass::openMapset(QString, QString,
> QString)’:
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:611:46:
> G__setenv( "GISRC", mGisrc.toUtf8().data() );
> member function ‘static QString QgsGrass::closeMapset()’:
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:657:39:
> G__setenv( "GISRC", ( char * ) "" );
> member function ‘static bool QgsGrass::region(QString, QString,
> QString, Cell_head*)’:
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:1082:83:
> error: ‘G__get_window’ was not declared in this scope
> G__get_window( window, ( char * ) "", ( char * ) "WIND",
> mapset.toUtf8().data() );
> member function ‘static bool QgsGrass::mapRegion(int, QString,
> QString, QString, QString, Cell_head*)’:
> /tmp/makepkg/qgis/src/qgis/src/providers/grass/qgsgrass.cpp:1268:94:
> G__get_window( window, ( char * ) "windows", map.toUtf8().data(),
> src/providers/grass/CMakeFiles/qgisgrass.dir/build.make:60: recipe for
> target 'src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o'
> failed
> make[2]: ***
> [src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o] Error 1
> CMakeFiles/Makefile2:1251: recipe for target
> 'src/providers/grass/CMakeFiles/qgisgrass.dir/all' failed
> make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
> Makefile:137: recipe for target 'all' failed
> make: *** [all] Error 2
> So I'm not sure what the hiccup is exactly. GRASS 7 is installed and
> runs fine outside of QGIS, but maybe it's missing some environment
> variables (like GISRC or GISDBASE) that QGIS needs to compile against it?
> Donovan
> Qgis-user mailing list
Firmas de correo.com : José Antonio Barreña Cayuela
/Biólogo (botánico). Servicios Ambientales/
*+34 677 811 883* · jabarcay at gmail.com <mailto:jabarcay at gmail.com>
skype <skype:jabarcay?call> linkedIn
<http://es.linkedin.com/pub/jos%C3%A9-antonio-barre%C3%B1a-cayuela/26/936/15a/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150312/c24cd60b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150312/c24cd60b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150312/c24cd60b/attachment-0001.png>
