[Qgis-user] Export polygon coordinates qgis
Lester Anderson
arctica1963 at gmail.com
Tue Mar 17 01:57:49 PDT 2015
The important point is to make sure the shapefile is in a proper projection
and not just a cartesian reference. Then you can export the vertices after
reprojecting.
There are other ways to do this via GMT too.
On 17 March 2015 at 08:50, Enrico Ferreguti <enricofer at gmail.com> wrote:
> You can simply copy selected features from attributes table and paste them
> to excel table.
> in the first column you will find magically the geom attribute in WKT
> (Well Known Text format) containing all vertices coordinates expressed in
> layer srs.
> To get lat/long in geom field you need to explicitly reproject layer with
> vector or processing tool. Reproject on the fly does not apply on copy &
> paste geom field.
> Regards
> 2015-03-17 9:08 GMT+01:00 Tomasz Bigaj <tomek at jagielka.eu>:
>> Hello,
>> I need to export polygon coordinates from shp to text file.
>> I can mark an object on map and use “Ctrl+C” but only x y coordinates are
>> copied.
>> How can I recalculate X Y coordinates to get lat/long geographical
>> coordinates? I’d prefer to do it in Excel, because have a lot of extracted
>> X Y data.
>> Regards - Tomek
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150317/056b3ae3/attachment.html>
