[Qgis-user] Export polygon coordinates qgis
Lester Anderson arctica1963 at gmail.com
Tue Mar 17 02:01:33 PDT 2015
Have you assigned a projection to your shapefile?
On 17 March 2015 at 08:59, Tomasz Bigaj <tomek at jagielka.eu> wrote:
> Hi Lester,
> Thanks, it works but… I still get XY coordinates, not lat/long. The
> question i show to convert from XY to lat/long ?
> Regards – Tomasz
> *From:* Lester Anderson [mailto:arctica1963 at gmail.com]
> *Sent:* Tuesday, March 17, 2015 9:48 AM
> *To:* Tomasz Bigaj
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Export polygon coordinates qgis
> Hi Tomasz,
> This is easy to do.
> Go into edit mode and select the feature(s) you want (highlighted yellow
> usually). Open the attribute table for the polygon shapefile and click
> "copy slected rows to clipboard" (4th icon from the right on the toolbar).
> Copy this into a text editor and you get something like this:
> wkt_geom    id
> POLYGON((-2.72439024390243922 1.60975609756097571,-2.72439024390243922
> 1.95121951219512213,-1.77073170731707341
> 2.02926829268292686,-1.57073170731707323
> 1.42926829268292699,-2.21951219512195141
> 1.06341463414634152,-2.72439024390243922 1.60975609756097571))    1
> Just edit this file to leave the X, Y coordinates and away you go!
> Coordinate pairs are separated by commas.
> Cheers
> Lester
> On 17 March 2015 at 08:08, Tomasz Bigaj <tomek at jagielka.eu> wrote:
> Hello,
> I need to export polygon coordinates from shp  to text file.
> I can mark an object on map and use “Ctrl+C” but only x y coordinates are
> copied.
> How can I recalculate X Y coordinates to get lat/long geographical
> coordinates? I’d prefer to do it in Excel, because have a lot of extracted
> X Y data.
> Regards - Tomek
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150317/242a06fa/attachment.html>
