[Qgis-user] Where is the update to QGIS 2.8 for Fedora Linux?
Christy Nieman
cnieman at dmsolutions.ca
Tue Mar 17 07:55:40 PDT 2015
Fedora 20 does not have QGIS 2.8 in its repository, nor 2.6 for that
matter. Are you already using a third party repository?
On 17/03/15 10:47 AM, weatherman21 at nc.rr.com wrote:
> I tried installing it from the Fedora 20 terminal, with the command given me from the QGIS download page for Fedora:
> sudo yum update
> sudo yum install qgis qgis-python qgis-grass qgis-mapserver
> When I did this, I only got the 2.6 build and not 2.8. Is this the Fedora repository?
> Jacob
> ---- Christy Nieman <cnieman at dmsolutions.ca> wrote:
>> If you installed QGIS from the Fedora repository, QGIS 2.8 will probably
>> be available with the Fedora 22 release. If you want 2.8 before then,
>> you'll have to install from a third party repository or build it
>> yourself. I unfortunately cannot suggest a repo to install from as I
>> build it myself.
>> Christy
>> On 17/03/15 10:16 AM, dave.potts at pinan.co.uk wrote:
>>> Try refreshing your browser cache?
>>>> I am receiving a message in QGIS 2.6 that 2.8 is available, but when I go
>>>> to
>>>> update it, Fedora says there is nothing to do, then when I try a straight
>>>> install, it tells me the latest build is still 2.6 for Fedora. Any
>>>> suggestions?
>>>> Jacob
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
