[Qgis-user] Qgis 2.6-2.7-2.8 on windows 7 OSGeo4W installation. Oracle layer save as shape doesn't work because of SE_ANNO_CAD_DATA blob field
Carlos López PSIG carlos.lopez at psig.es
Tue Mar 17 08:53:43 PDT 2015
Hi Diana,
How are you?
Shapefile doesn't support this kind of field...
You could to try to convert to spatialite o gml!!! or change this field to
varchar (254)
Best regards,
Atentament!!!
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2015-03-09 11:45 GMT+01:00 Lopez Agostini, Diana <diana.lopez at gencat.cat>:
>  Hi,
> We’ve got several gis vector layers in a spatial oracle repository.
> We need to export them (both geometry and attributes) to shape format
> files using qgis.
> 1)      The ‘save as’ shape crashes, giving the message:
> Export to vector file failed.
> Error: unsupported type for field SE_ANNO_CAD_DATA
> SE_ANNO_CAD_DATA is a BLOB type filed
> We’ve tried qgis 2.6, 2.7 and 2.8 on Windows 7 (OSGeo4W installation).
> 2)      We’ve also tried hiding the field SE_ANNO_CAD_DATA before
> executing ‘Save as’ shape without success:
> Do you know a workaround for this issue ? Is there any way to omit the
> column SE_ANNO_CAD_DATA from the export ?
> Thanks in advance,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150317/96791e13/attachment.html>
