[Qgis-user] Oracle connection Timeout
    Heather Hillers
    Heather.Hillers at erftverband.de
    Wed Mar 18 02:01:05 PDT 2015
This morning we tested the patch
[1] https://github.com/qgis/QGIS/commit/db23632
using qgis-dev nightly build 2.9.0-24.
We installed locally on Windows and tested with Wireshark.  On loading a
Project where Oracle layers were stored without a username and Password,
1. A first Connection stream ConnA was built (sig, ack) and recieved a Login
error.
2. ConnA was cleanly ended (Fin) and did not recieve a RST from the Oracle
Server.
3. A second Connection stream ConnB was built (sig, ack) with the
QgsCredentials given username and Password (sig, ack) and was cleanly closed
when the Project was loaded.
A tail of Oracle logs showed no Errors.
We tried restarting QGIS, reloading the Project, loading a bigger Project,
and adding and removing layers.  Everything was squeaky clean.
We connected to a Oracle 11 and to an Oracle 12 and to an Oracle 12 on an
ODA without Problems.
So, this patch is great.  Brilliant!
The next question is, how can I deploy it to my productive System?  Since
this is a System error that causes a lot of trouble, it's really important
to get it fixed.
Will it be added to / is it already added to 2.8?  Is 2.8 now the official
QGIS stable Version?  We still have 2.6 on production.  Is it safe to
upgrade?
Thank you so much,
Heather
View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-connection-Timeout-tp5193601p5194112.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
