[Qgis-user] 3D analyst
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Mar 18 09:09:14 PDT 2015
Not sure what you are trying to do.
-If you are looking to extract contour lines from a DEM, use
(Raster/Extract/contour) or Processing/Grass r.contour.step (with more
options.)
-If you want to extract a terrain profile from a DEM, use Profile tool
plugin.
-If you want to extract a terrain profile from a vector file (containing
contour line), I believe the VoGis-ProfilTool Plugin, will do that (but
never used it). If that does not work, make a DEM with these contour
lines using the Interpolation Plugin then use the Profile tool plugin.
To install plugins: Plugins/Manage and install plugins/All or not installed.
Good luck
Nicolas
Le 2015-03-18 10:11, Shetie Gatew [via OSGeo.org] a écrit :
> Dear all,
> Is there any one who has used 3D analyst to extract topographic
> profile with line extrapolation using QGIS? would you please share me
> how I do it with QGIS. There is in ArcGIS. I saw in in some tutorial
> from you tube
> Best regards,
> Shetie Gatew Mitiku (PhD student)
> Department of Biology
> Arba Minch University
> [hidden email]
> </user/SendEmail.jtp?type=node&node=5194191&i=0>;[hidden email]
> </user/SendEmail.jtp?type=node&node=5194191&i=1>
> +251-913-070305
> Ethiopia
> Earth and Environmental Science
> Katholic University of Leuven
> Belgium
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5194191&i=2>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/3D-analyst-tp5194191.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/3D-analyst-tp5194191p5194242.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150318/4fe8a260/attachment.html>
