[Qgis-user] Problem installing QGIS 2.8 in Fedora 20
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Mar 18 09:55:27 PDT 2015
Hi
On 03/18/2015 04:06 PM, weatherman21 at nc.rr.com wrote:
> When I attempt to install QGIS 2.8 on Fedora 20 from the QGIS download page, I get the following error message in the terminal:
> Error: Package: qgis-mapserver-2.6.0-1.fc20.x86_64 (qgis)
>            Requires: libqgis_analysis.so.2.6.0()(64bit)
>            Available: qgis-2.6.0-1.fc20.x86_64 (qgis)
>            Available: qgis-2.0.1-6.fc20.i686 (fedora)
>                Not found
>            Available: qgis-2.0.1-7.fc20.i686 (updates)
>                Not found
>            Installing: qgis-2.8.1-8.fc20.x86_64 (qgis)
>               ~libqgis_analysis.so.2.8.1()(64bit)
>  You could try using --skip-broken to work around the problem
>  You could try running: rpm -Va --nofiles --nodigest
The package qgis-mapserver was renamed to qgis-server.
Try uninstalling qgis-mapserver first (and install qgis-server
Matthias
