[Qgis-user] Trouble trying to produce large graphic jpg from stand alone QGIS 2.8.1-Composer on Windows 7-32 bit
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Mar 19 01:46:49 PDT 2015
Hi Tom,
I remember there used to be a problem with large prints in Win32, see
e.g. [1]
Bernhard
[1] http://hub.qgis.org/issues/11145
Am 18.03.2015 22:22, schrieb Tom Lennon:
> The graphic is 656 MB (16200 x 13500 @ 300 dots per inch) and would
> measure 1372 x 1143 mm. It is a wall map. Composer warns it may cause
> memory overflow and when I proceed it says to either change paper size
> or resolution and no file is generated. I have checked available memory
> and it is 1.82 GB before attempting the export. Windows 7-32 is limited
> to 3.5 GB physical RAM so I tried increasing virtual RAM to 12 GB. That
> had no effect. Also tried to output as PDF, which gave no warnings and
> produced an empty file. Is there some way to instruct QGIS to use the
> virtual RAM? Or is there a way to have the output file made in bands
> like Post Script does?
> Thanks
> tolennon at gmail.com <mailto:tolennon at gmail.com>
__________ Information from ESET Mail Security, version of virus signature database 11343 (20150319) __________
The message was checked by ESET Mail Security.
http://www.eset.com
