[Qgis-user] Cell statistics
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Mar 19 04:14:31 PDT 2015
You can look at some basic statistics in the layers properties by right clicking on the layers. Those are sometimes wrong. Best to use the gdal raster statistics in the processing toolbox plugins or the grass module in the same toolbox.
The gdal module in the raster\ menu can sometimes give wrong results if the .XML file has been created. If you delete it, if will give you good results. The XML file with the statistics is created if you open and close a layer for the first time. Look in same directory as your raster to find and delete the file. Depends on the version Qgis. Bug may have been fixed.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
Le 2015-03-19 06:56, "Md.Azizul Haque [via OSGeo.org] " <ml-node+s1560n5194411h2 at n6.nabble.com> a écrit :
Dear QGIS Users, I need to compute cell statistice from a raster by QGIS. Would you be kind enough to help me ? Thanks and regards Azizul _______________________________________________
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Cell-statistics-tp5194411.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cell-statistics-tp5194411p5194417.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150319/aef169c0/attachment.html>
