[Qgis-user] Starting QGIS with pre-configured settings
McDonaldR
McDonaldR at angus.gov.uk
Thu Mar 19 05:53:05 PDT 2015
Hi Saber
Thanks for that - sorted.
What was confusing me was how to generate the INI file in the first place. Starting QGIS from the command line with the - - configpath option set to C:\temp\qgis2 sorted that. And then setting all the options in QGIS wrote the settings to the INI file (including PG and WMS connections). And this file can now be copied to the shared drive (or to each laptop).
That's just saved me three hours!
Cheers
Ross
From: Saber Razmjooei [mailto:saber.razmjooei at lutraconsulting.co.uk]
Sent: 19 March 2015 12:27
To: McDonaldR
Subject: RE: [Qgis-user] Starting QGIS with pre-configured settings
Hi Ross,
You can set it once, save it on a shared drive. And change the bat file to start qgis with that config file:
start "QGIS" /B "%OSGEO4W_ROOT%"\bin\qgis-bin.exe %*
to
start "QGIS" /B "%OSGEO4W_ROOT%"\bin\qgis-bin.exe --configpath X:\FOLDERWHERE USER HAVE FULL ACCESS\.qgis %*
X:\FOLDERWHERE USER HAVE FULL ACCESS should be something like this: h:\%USERNAME% this is, for example, the shared folder for each user on h: drive in windows.
For WMS and PG connection, maybe you can set one, save it and share it with others.
Cheers,
Saber
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of McDonaldR
Sent: 19 March 2015 12:05
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Starting QGIS with pre-configured settings
Hi List
I need to run QGIS on a set of laptops (8) for some short internal training sessions for 24 different users. How can I get QGIS to start with some config options (see here http://qgis.tips/tip/10) so that each user has a PostgreSQL connection, a couple of WMS connections and some default options set (rendering, CRS, proxy, etc)?
Getting each user to set up the connections and options takes a chunk of time at the beginning of the session. Get all users to open a default project with the training layers loaded?
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
________________________________________
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
