[Qgis-user] QGIS on WinXP
Andre Joost andre+joost at nurfuerspam.de
Thu Mar 19 09:30:45 PDT 2015
Am 17.03.2015 um 07:08 schrieb Evert Groenewald:
> Installed Qgis 2.8.1 last week on XP. Had problems with 32 bit net
> install, so used 32 bit stand alone installer. Don't know what
> happened during net install as I had to leave the computer during
> install process, but the result was a incomplete install. Qgis not
> present after install but Grass was present.
Please look into the postinstall.log for any error messages.
My XP version started with error messages because of msvcrt version
conflicts. Deleting the msvcr90.dll from windows/system32 solved the
issue. See
<http://gis.stackexchange.com/questions/72506/how-to-fix-runtime-error-r6034-an-application-has-made-an-attempt-to-load-th-c>
if you run into that.
Cleaning the PATH variable might help too.
HTH,
André Joost
